ATS Aurora turbos
Huff or Bark that is the Question.
Intermediate Shaft?
I agree I like the sound of the 62 for the pulling that I do and it is cheaper, am just getting ready to order one once my VP is finished with the FASS
The turbos are equiped with the necessary parts to bolt to the factory configuration and are available with a 4inch downpipe.
Gypsyman said:
Can you verify the direct replacement statement as I haven't seen one installed yet. I don't want to lose my turbo mount Jacobs. :D
Hohn said:
Anyone using them? I haven't seen a peep of them mentioned on the boards!
I'd like to see if they are as good as the B1 and USB turbos that are in the same price range...
Justin
I am using a Aurora 5000 in a twin set-up as the small turbo with a B-52 as the low pressure turbo and I must say I am very happy with it. :D With a set of modified 370 injectors they are producing. :D 105lbs of boost, 105lbs of drive pressure, and with the 52mm wastegate dumping to the B-52 it's pumping out 50psi
