ATS Manifold Installation
why not adjust valves with a dial indicator??
Amsoil changes
I'm checking out what's involved with this installation and the only problem I see is a bracket from the upper manifold bolt on #3 cylinder supporting the boost line to the AFC control. I can't figure out how this bracket reattaches to the ATS manifold.
Has anyone else encountered this problem? What did you do to solve it?
Thanks, Dave
1996 Dodge 2500 4X4 SC, SLT, Cummins 12V, 5-spd. , JRE 4" exhaust (my kitty ran away into the woods and the muffler fell off!), TST 280 HP/685 Ft-Lb Uprate Kit, AFC Spring Kit, Horton Fan Clutch, Jacobs/Ram Exhaust Brake, MagHytec Differential Cover, Prime-Loc, Rancho RS9000 Shocks, Combo Gauge, K&N Air Filter, Brite-Box, Geno's finger-touch oil pan drain plug, Optima Yellow Tops, no turbo silencer ring, full-time fog lights.
Just cinch it down with some baling wire so it doesn't vibrate. It is just the wastegate line--no big load on it. I wouldn't hold it against the port area of the manifold s that gets real hot. You could make and bolt a tab under the manifold bolt and attach it to the tab.
Bailing wire come on Joe!!!!!! In my case there is no line going to the wastegate because of the 16 housing but I would suggest just making a new bracket if need be.
