GrantP
Last month I finally replaced the original exhaust manifold on my '97. The manifold had shrunk to the point that the #1 cylinder exhaust gasket was leaking. The #1 gasket was deformed around the bolt holes showing just how much the manifold can shrink (pic below) When I removed the manifold, the bolts were rubbing very hard against the side of the manifold. There would have been no way to actually thread those back in if I had to re-install the old manifold.
I bought the ATS manifold from Geno's which came with new gaskets. The only additional item I needed for the job was a can of PB blaster to remove the turbo mounting studs from the original manifold (soak them good, give it time, they will come out). I didn't bother removing the turbo for the install, I left the oil line and exhaust attached to the turbo and just moved it aside but it was a tight fit.
Here's where I went wrong, if you're about to do this job, do yourself a favor and lay the new manifold on top of the old one and make sure the bolt holes line up. It's a LOT easier to do on the workbench than it is on the engine! I probably wasted an hour trying to whack the manifold with a rubber mallet to get the joints lined up with the bolt holes in the head. Other than that the install went smoothly, no broken bolts, no bloodshed.
I am not impressed with the mounting hardware from ATS, about 1/2 of the split washers in the kit didn't even fit the bolts (too small) and I'm not a big fan of the allen heads since it makes access difficult in some spots. There is a boss to mount the heater core hose support in the manifold, but they left out the mount for the AT cooler line. Maybe I'm just being picky.
I've had the new manifold on for a month and I've noticed two things since. Gas mileage is up and boost & EGT's are down. I don't have exact readings on the mileage yet since I haven't burned a full tank with the new manifold but I already have a lot more miles on the first half tank than I normally would. I attribute most of that improvement to fixing the exhaust leak (energy wasted to the atmosphere instead of spinning the turbo). I didn't expect the boost to go down but it makes sense if the airflow is really that much better in the ATS manifold vs. the OEM. At highway cruise speeds boost is down about 2 psi and EGT's down ~100 running empty. I haven't noticed any difference in power. All in all I'm satisfied with the purchase and I'm eager to see the MPG improvement over the leaky stock manifold.
