Originally posted by Vaughn MacKenzie
Stock power levels probably won't help much, boosted HP it should knock maybe 50F off, but by the time you're running big HP the turbo will the restriction, so you won't see much benefit from the ATS until you do something about the turbo. If you're on a budget, Piers' Bomber Lite 3G turbo is better than stock and costs less than an ATS. That's the combo I have right now and am pleased with it (unfortunately I can't comment on EGTs since I don't have gauges).
Vaughn
Agades 400hp is well beyond what your stocker should handle! (If you're talking rear wheel HP). At 400-450 you should be looking at a PDR40, DD Jammer, Bell USB or the likes. Definitely beyond the Bomber Lite turbo. If I were to put a HP range on the Bomber Lite I would say Stock to 350hp, and only higher if you don't plan to use the power much. And ONLY with GAUGES, GOT THAT?
Heh. . no gauges? . . yeah, Bad Vaughn. Very Bad Vaughn.
Piece of advice: Do what Vaughn says, not what Vaughn does :-laf
Originally posted by Greg Boardman
Vaughn, I thought you knew better buddy? You've been here since 1999 and still no guages.![]()
Do these manifolds come with gaskets?
