i am a avid ATS fan. . i run a 94 cummins with 700 hp and 1500 + lbs of torque, i pull professionally, i run the ats tripple lock converter. Before i replaced the stock intermediate shaft(clean break)with a billiet ats shaft and the stock output shaft (with a hardened shaft) after they broke, even with these breaks it never even flinched my ats tc, clint at ats assures me never once has a ats tc quit,or broke... . you cant beat that. . my ats converter is quick, it has the highest stater speed and the most torque mulitplication , ats has the only valve body that allows you to lock your converter manually with a mystery switch. . other then a stock and hold and not burn out. ( ps never mix the trans parts. . doesnt work so well. ats, its never bowed or buckled on us once. you may be paying cheaper, but cheaper isnt always better. I ve worked with both and ive replaced dtt with ats, i have experience and have tested the limits of these transmitions in several pulling trucks, race trucks, dodge, ford and gmc. I hope you take the time to look futher and see the differences i have.
