175 isnt bad. Just wondering what it'll be at 100+ ambient with a load or working it harder.
Guess I'll find out this summer.
Absolutely NOTHING!!!
EVERYTHING........if you are a retailer like ATS or RevMaxWhat's wrong with 175°?
He said the cooler the better.
I saw 174° on a couple mile steep pull in 1/2 at approx 18K GCW on a 80° day.
I'll have some more slow and steep pulls this fall to see how hot it gets.
I have also tried 4Lo to get into a higher gear so the TQ converter would lock but it wouldn't lock below 20 mph regardless of gear... there goes my idea of 4.10's helping at low speeds get to TQ lock sooner.
That's interesting, my old box locks up at around 10mph in 2nd Gear 4lo. And stays locked till down to around 7mph.
All with EB switched ON.
Installed the bypass today. Am I going to see any negative effects from doing so?Did a little more slow towing last weekend and 20 mph does seem like the program limit for lockup, but I didn't try 4LO.
Trans temps got up to 175° for me at ~18K GCW, and 188° for dad at ~21K GCW.
So that got me thinking, what temps are programmed for the fan in relation to trans temp.
Here is what I found on the stock file for a 2018. Aisin and 68RFE are the same.
Fan engages at at trans temp of 194°F.
Fan maxes at a trans temp of 234°F
Fan engages at a TQ Converter outlet temp of 237°F
Fan maxes at a TQ Converter oulet temp of 275°F
Bottom line... Ram doesn't seem that concerned about any of the temps we are seeing, and then some.
I can't look at the Aisin programming as it's stand alone, but the 68RFE requires 1250 rpm on the turbine output shaft to go into lockup (~35 mph)... that seems really high!
Well, guess I’ll see how it goes. I can always reinstall the stock valve.Depends on the climate you live in, even then it will take longer to warm up and my 0.02 is that’s not good.
I’m still not certain it’s a real issue, but rather a marketing gimmick.
I think adding a thermostatic bypass to the trans was a big benefit over older transmission cooling systems.
There is a reason thermostats are used for many different applications.
