snowracer69 said:Ditto!
Of all people ATS should be taking care of, Nate should be at the top of the list. Give the guy a new transmission... chalk it up to serving your country if you have to. No Mark, helping one guy out and doing the right thing won't put them out of business... in fact, it will probably pull in MORE business in the long run. That's the way good customer service works.
I can't believe he payed labor for warranty work on a brand new transmission.![]()
Joel Richards said:...
Did you forget that Chuck in Seattle rebuilt your second transmission, not ATS? Because I felt that YOU were not at fault, and Chuck would not stand behind his work, I replaced your transmission at no charge to you whatsoever.
I appologized for the problem and inconvenience every time I spoke to you or your wife, and shipped your transmission in front of 7 others that were scheduled to leave before yours... all in hopes that you would make it back for the wedding (which I truely hope you did). We realize that there was a huge inconvenience to you, and did everything in our power to make sure that you got back on the road ASAP...
BillZ said:... .
Feb 2004: Paid $6,000 for ATS torque converter and transmission.
March 2004: In shop to repair vacume lines installed incorrectly by ATS in Denver.
July 2004: Torque converter completely failed - ATS repaired (2 weeks down)
Aug 2004: Back to shop to install $5 part to prevent line pressure over-load faults. 120 miles driving to install a $5 part that ATS should have installed originally.
Jan 2005: Valve stuck open - low line pressure - transmission wasted! Sat in Yuma for 3 weeks while ATS decided it was their problem. And then they asked me to help pay!!...
BillZ said:When our 1st ATS transmission failed, I called ATS and they directed me to their fella in Seattle (about 60 miles one way). The Seattle transmission guy diagnosted the problem and he and ATS arrived at their solution (which was replace the TC and rebuild the rest of the transmission with all new parts sent to the Seattle transmission guy from ATS). The Seattle transmission guy (Ed's Transmission) really took good care of us - he always gave us the feeling he just wanted to get the thing fixed and get us back on the road.
I don't want to even attempt to second guess why ATS decided to have Ed's rebuild the transmission and that's not my issue - but Ed's did rebuild it under ATS' direction and guidance.
When the 2nd transmission went out, the fella in Yuma (Southeast Diesel) said this one was shot, ATS (after looking at our failed transmission) decided to ship an entirely different rebuilt transmission with another new TC. ATS reported that they tested this 3rd transmission 3 separate times with 3 different mechanics - they said this was the last time they wanted me to have a failed transmission.
SO, ATS did stand behind their product - I just was hoping for more compassion and a little more speed...
Here's my experiences with ATS and their torque converter and transmissions:
I'm not impressed with ATS nor their products. Their customer service is probably the worst I've ever experienced.
OTRPU said:The juries still out on mine. But everybody but ATS agreed that transmission took out my flex plate which ended up with me having to rebuild a new Cummins 24v. I'm not talking one or two shops, I've had problems coast to coast and I'm scared to death I'll be left laying along the roadside again. That transmission tears out input shafts. The controller wouldn't downshift or unlock and it tears u joints and rear yokes up. Had a new yoke and u joints installed in Indiana. By the time I got to Denver, ATS took a look and told me the yoke was spread and needed to be replaced, as well as bearing straps. So I had them throw one in. Went north, Montana shop said yoke is spreading and should be replaced. Low on money and time I just had them throw in new u joints. Got to Oregon, same story. This stuff don't wear out every other state just cause I'm hauling and empty camper around. So back to ATS I go, they look, say they can't find a thing wrong with the transmission. So we go for a test drive with me driving. They didn't agree that it's slipping, but did agree that the commander wasn't unlocking soon enough and made adjustment to the box. I've done fluid & filter changes every ten thousand miles. I'm gonna have Angola change the fluid and filter tomorrow. Can't wait to hear what they find in the pan. Angola had driven it and he doesn't feel the slipping. Maybe I'm full crap, but locked in OD, cruise set, trailer on, when it goes up hill I feel a serging. And it shows with RPM increases/fluctuations on the tach. Only thing I don't understand is if it's slipping like I claim why aren't I seeing an increase in transmission temp. Maybe not slipping enough. But if I kick off cruise and downshift it goes away. You tell me, does that sound like it might be slipping? Maybe I don't know what slipping is. But it's cost me thousands to go back and forth accross this country and every time I have to have anybody look at it I'm told the transmission/commander is the cause of all my problems. What do I know?
Cheers,
Steve J
MLeppen said:"They didn't agree that it's slipping, but did agree that the commander wasn't unlocking soon enough and made adjustment to the box. "
If that means shifting while TC is locked... ... I've heard bad things can happen.
The only solution I can come up with to stop this is to institute a rule that when it comes to automatic transmissions if a post is started about ATS trannies ONLY those with ATS trannies or stock can post to it. If a post is started about DTT trannies then ONLY those with DTT trannies or stock can post to it. Likewise with BD, Suncoast, Goerend, or others. I find it sad that it has to come to this but I don't see any other workable option based on the track record. These battles have been hashed out over and over again and nothing has come out of them other than people being ****** off and driving users away from the site. From here on out we will be deleting posts based on this policy. If you see a post that falls under this policy DO NOT fire back at that person - simply report the post and it will be taken care of.
If a post is asking a general transmission question you can post how your transmission modification works - but DON'T discuss the other side AT ALL. Posts WILL be deleted with no notice that do not meet this standard.
snowracer69 said:Short of a miracle? WHAT? The E4OD is inherently a stronger transmission than the 47RE. Why is it a miracle that it held "for a few seconds"?
How many runs at 800+ have others thrown through other auto trannies (47RE's for that matter... which, as stated above, are inherently a weaker design) w/o any breakage or damage?
