holmanrd said:Ok, I have been reading this thread since the beginning. It’s full of great info. and some horn blowing as well. Sometimes it is a little bit too much info.
For a newbie like me, can some of you cut to the chase and give me your suggestions on the transmission upgrades I might want per my needs. I pull a bit of weight now and then. I don’t know the weight of my stock trailer (18foot steal gooseneck loaded with beef or horses?) but I do pull a gooseneck flat bed with a couple of jeeps and a bunch of camping gear that I would estimate weight to be over 8K maybe 10K loaded (Just an estimate).
In addition to my signature I have “lost” my EGR, bought a #10 plate, AFC spring, and 3000 GSK. I do want the truck to spool up fast and get the load going. I want it to run as cool as possible. I still want to be able to hot dog and jump on it around town. Heck I just want to get the most use out of the power I have right from the start, loaded or not.
I appreciate any response, biased or not, dealers or users. Thanks in advance.
My comment would be to call the transmission companies and ask them these questions. Then I would PM a few folks on here and ask them about their set-ups. I would pick those people that maybe hang-out in the tow/hauling section since you are concerned with that aspect of it.
But do understand, efficient converters are not only offered by one vendor. As a matter of fact, the others started out very efficient and over the years have found a balance between efficiency and lock-up. If you are not running big power, you may not "need" a triple lock, but I would want a billet cover. More surface area for more clutch material will mean for longer life at minimum. Just my non qualified opinion.
Stefan, the test was done on my dyno. 3 runs were made on a 03 Dodge with stock transmission. After the new unit was installed with a triple disk converter, it was dyno'd again 3 more runs. All within 3 hours of the original runs. All 6 runs were within 1hp. Understand, this was a test where I was proving that the billet cover robbed HP. The only reason I could come up with why it didn't was that the diesel tq reduced the amount of hp actually lost. But I can tell you on an acceleration test, on a dyno that everyone says doesn't load these trucks (which should have made this HP loss due to more rotating mass more evident) we saw no power loss. None.
