I too am torn here. I bought a complete, Full DDT trans 18 months ago, with converter, and it has slipped. It has lots of miles on it. I run about 320 HP on my 96 12 valve, but regularly am grossing 25,000# plus, with real "odd" tall loads that catch LOTS of wind.
Bill has been very helpful, and has offered to look at the trans, no charge. Problem is that freight and labor to pull and return the unit to him will be well in excess of $1000. 00, and (at first) it looked like simple bad converter. I have a local shop working on it, and he seemed "pretty knowledgeable". From a cost standpoint, the shop will charge $350 to $500 to change the converter and inspect the trans.
When he pulled the trans, the converter was toast, (and the direct clutch pack, more on that later). Bill sent me a New converter under warranty, but was concerned about he reason for the failure. (I was not told of the bad direct clutches until much later)
BUT, there was one other problem. During the repair process, my trans guy could not get the DTT converter to lock up when installed! He pulled the trans again, and checked the DTT converter per factory shp manual methods (air pressure) and could not get it to stop leaking! But that is ok, because he has his own supplier that builds a HD BILLET converter, that he will guarantee.
I was faced with my local trans guy telling me that he would not recommend installing a converter that would not seal. He even showed me how he tested it, (per the FSM) and then tested a stock unit, which did not leak! Even shows me where the computer is telling the DTT converter to lock up, but it is not locking up! HMMMMMMMMM.....
Well, I figure I will just send back the DTT converter, and go with this guys converter. I mean DTT has a great warranty, but he is so far away, it really is impractical for me to use, and the warrenty is up in a few weeks anyway. This guy is local, I am paying him for all his labor anyway, and he will stand behind his work, and converter, with a new one year warrenty, so it is a sale. I get my truck back, with his billet converter, and all is well... .
For one, when I hit 48 MPH, the new converter is locked. Period. Locked. I have more than one CTD, and this new converter locks in just like my stock trucks. I like that! It locks every time, at the right speed.
The old DTT converter sometimes locked up, but, sometimes it would go for miles before locking up (like when the cruise control is on). This always DROVE ME NUTS! I have replaced the TPS, re routed the wires, installed noise filters, but still, the DTT converter never consistently locked up.
BUT... Problem with the new converter is the stall speed. I mash the throttle down, and the rpms shoot to 2600+ and stay there, (lots of noise, but not a lot of speed) right until the converter locks at 48 MPH, and WHAM, it is pulled down to 1500 rpm in a split second.
I am no expert, but I can see 1000 rpm drop in a split second under full throttle is going to be bad. Just the flywheel effect alone is bad. I call my local guy, and he says his converter is a little lower stall than stock, but it still stalled at 2300 rpm with my engine power.
Anyway back to the point, This new converter locks up every time, just too hard. So I figure, to make this thing last, I will either lift foot at lock up, or install a lockup switch, and keep it unlocked until I lift the throttle. All is fine for a couple of weeks. I am running my other trucks on the long hauls (this one has 308,000 miles now)
After two weeks out of the shop, I finally hook up to 12,000# load, and it locks down at 50mph, and the tach drops from 2600 to 1900 in a instant. Wait a minute! My RPMS at 50 mph is supposed to be 1500, not 1900!!!! I let up off the throttle, boost drops to 20 psi, and RPMs drops to 1500. I mash it back down to 30+ psi of boost, and rpms go back up to 1900. THE SOB is slipping under a load!
NOW, I call my local guy, and he tells me that he did find the direct clutch burnt in addition to the converter. He went thought the trans, Replaced the seals, fibers and steels, and put it back together, finding no other problems.
In the meantime, I call Bill at DTT. He offers a real bit of knowledge: First, the converter he built was designed for a delayed lockup!!! The normal air test will not work on his converter. Somehow, it has a oriface to delay the lockup until the throttle is lifted some. I just wish I had known this before I spent all that time and money trying to fix it! Second, he is convinced that the burnt direct clutch contaminated the fluid, and caused the converter to not seal, and slip.
Makes sense.
Anyway, the truck is back in the shop, he does not have time to look at it. Maybe tomorrow. I am stuck. The DTT converter I am told will work, but will have the delayed, inconsistent lockup, and this whole leaking thing has me worried. The local guys converter locks up right, but is too loose. It can tell you from driving with both converters, the important thing is a LOW STALL. Running 2600 to 2800 rpm at 3 or 4 MPH is crazy. (I run a 4" exhaust pipe, no muffler, which exits IN FRONT of the back tire! Scary!) But my local guy wants to sell his billet converter. I really like his dependable lock up, and am prepared to buy the lock up switch.
I think Bill has the right idea. In order to save the input shaft and other parts of the trans, the lock up must be delayed until it is not under full throttle. Besides, with a low stall, the truck pulls pretty good even when unlocked. BTW, Bill does offer other converters that lock right away, but recommends they be for drag only, and I can see why!
My trans guy did "look" at the truck, and told me the stall speed in reverse is in fact 500 rpm lower than in forward (drive) so it is not the converter this time, but the clutches. He just does not have time to fix it, so still know one knows why it slips! When he gets that problem solved, (and I am sure he will) I am going to have to make a converter decision. I am leaning towards the DTT, knowing what I know now.
Paul Smith
www.NeedaTrailer.com
