auto transmission cluth packs...?
Intalling Pyro Probe
a fix for torn vinyl??????
They all do it! We all know they add clutches to the different sets in the transmission to hold more power, but how many can you add? What is the advantae of adding 1 over 2? Why not add as many as will saely fit?
Tring to decide,
Andrew
There are several ways to get 5 clutch frictions in the front clutch of our trannies. Although several companies advertise, a 5 clutch direct clutch, the different ways of doing it make a HUGE difference in how well they hold up over time.
You sort of answered your own question when you said, why not add as many as will safely fit. 5 is easy to get, 6 is possible with a little work, and I'm sure 7 is possible, but you have a lot of other factors to consider than just number of frictions. The thickness of the steels themselves as well as the thickness of the steel in each friction disc is important.
When a clutch is applied, it slips ever so slightly as it comes on. During this time, enormous amounts of heat is created. Thicker steel aborbs the heat and doesn't reach as high of a temperature as when thinner steel is used.
It's the same concept as using a heavy front cover on Torque converters to dissipate heat if you can't keep the clutch from slipping. If the clutch isn't slipping, no excess heat is created and there is no need for a heavy cover, but that is another issue entirely.
One way of adding 5 clutches to the front clutch is to use the . 060" forward clutches instead of the . 080" front clutches.
But this is a cheap way of getting there because the only difference in these clutches is the thickness of the steel portion. I ran a setup like this for a while and the steels actually warped due to excessive heat. I have one hanging on the wall as a display.
The proper way of doing this is to use the . 085" frictions that are designed for the front clutch. They resist warping over time and will live longer than the thinner clutches.
Also, clearance in a clutch pack is often determined by the number of clutches. So as the number of clutches in a pack increases, the clearance should also increase to resist drag.
So, if you add clutches and also need more clearance, where does this extra space come from? The answer is either thinner plates or custom parts and expensive machining.
Even though several companies may have the same marketing hoopla, once you get into the finer details of the system there are right and wrong ways of accomplishing the same goals.
The reason this is so fresh on my mind is because I spent today playing with Cord's new automatic. It was stock this morning and I spent several hours scratching my head today trying to make this thing live without buying any special parts. I got 5 clutches in there, but there is a better way of doing it than what I did. But it didn't cost him over $150 for the entire rebuild. I can't wait to ride in it tomorrow to see how well (or poorly) it works.
I hope this answers your question,
-Chris
-Chris
Chris,
Thanks for the great post man! But here is what i don't understand. You make it sound like if you use the frictions that are . 085", you can not continue to use the . 080"clutches and that you have to use the . 060"'s that warped due to heat in yours. Am i reading that right? If that is true, then one or the other is going to become a weak point like you have hanging on your wall right?
Thanks for the help once again,
Andrew
Sorry. I guess I didn't write that clear enough. The clutches have a little variance in them. The direct clutches are . 080"-. 088", and the forward clutches are . 060" - . 068". So when I said . 080" and later said . 085", I was talking about the same friction disc.
You only have a certain amount of space to install the clutch pack.
Off the top of my head, factory allowable clearance is somewhere around . 075" - . 110".
If you just squeezed in another clutch disc and 1 extra steel plate, then you wouldn't have proper clearance and the clutch would drag.
So you have to come up with extra clearance somewhere. Depending on how well you do this will determine how long it will last and how much abuse it can take.
There ARE ways to use the thicker clutches and maintain clearance, but it is more expensive to build that way.
Ask your vendor how they come up with the space.
-Chris
do these trans have the thick "cap" right before the snap ring like the 700's had? if so changing this can add room. sorry but its been several years since i worked in the trans business and then was not a builder.
