I have a stock auto trans. , I am going to buy the git kit from banks. which is supposed to add 70 hp and 180 tq. the banks kit comes with tq lockup protection, the truck has 33000 miles on it, do you think I will be able to get another 30000 out of the stock transmission,the truck is a daily driver and if it pulls anything it is usually about 4000 lbs or less. The reason I am looking at the banks is because it has the tq lockup protection where as the edge ez does not. From what I have been told the transmissions starts to wear because when you add more power it causes the tq to slip while it is locking up. Is this correct. So if a box defuels the truck while the tq is locking up it should not cause premature wear correct. Also the transmission should not slip under normal driving should it???
