Auto transmission ??
Breather
Texas Ram Bash
What is the preferred fluid to use in 93 Auto? I believe it is the 46 or 47 RH?
It is is a 4X4 250 Cummins. Any other tips on this transmission welcome. Right now it works great!! Thanks.
93 ClubCab LE, 4X4,K&N,Tweaked,4" Straight pipe w/stack,BFG 315/75R 16's
106K, 10K-GVW Springs w/GN hitch.
Chrysler recomends ATF+3 or ATF+4. The +4 is available from the dealer or if you have a mind to go synthetic Amsoil has a +4 rated synthetic fluid.
Happy Trails
Thanks, Bob. Not sure how I feel about Amsoil, yet. I have a friend who sells it, and he pushes me toward it. Would be interested in some other opinions or experiences with it (amsoil)... either ATF or motor oil in Dodge.
I asked a simular question about automatics a while back and basically it sounds like the most important thing is to service the trans on a regular basis, make sure to shift down if the temp goes up, and most people are running a synthetic oil (I put in Amsoil +4, but Redline was also highly recommended).
HAPPY SLUSHBOXIN,and HAPPY RAMMIN,
Caleb
1993 LE W250 4x4 CC,Auto,3. 5's,Limited slip. Diamondplate,K&N,Egt,Boost,trans temp VDO Vision series, BD 3 1/2" Exhaust, 16cm housing,Mag Hytec Diff+ Trans pans,Transgo TFOD shift kit.
I've been using Amsoil in all of my transmissions. Never seen the temp guage go over 140 degrees, even when max loaded and max pulling. I have nothing but the tiny stock transmission cooler.
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, K&N, cleaned up exhaust, Dynomax straight-thru, rebuilt pump, intercooler, louvered fenders, 93 aftermarket smoothe grille; 78 35'Avion. Jesus saves!
BEWARE THE TPS!(Throttle Posistion Sensor) If you experience intermittent shifting into overdrive more than likely the problem is the tps. I'm on number four with 183,000 on truck
Gene
92 350 4x4
