My brother-in-law just traded his Cheby (which was having trans. problems) for a 2000 Dodge 3500, Cummins and auto. He's had it about 2 months now. A couple days ago, he was leaving work and it wouldn't shift from 1st to 2nd without letting off the throttle. It would run up to 2500rpm and not shift. 2nd to 3rd shift is fine. The trans pulls fine, doesn't slip, it just won't shift from 1st to 2nd.
He carried it by the Dodge dealer and $75. 00 later was told that it didn't set any codes, the pressure was fine at the governor and the trans needed overhauled. Then the guy tells him that he can try changing the governor and transducer and it might work. I told him not to do anything yet untill I asked you guys. The way I see it, if the trans needs overhauled, then just changing parts won't work.
What's the problem?
What's the problem?
