Autometer pyro fix
T-case buzzing fix continued
Transfer Case Capacity
A few years back I installed an Autometer Pryo. It never worked correctly, but I blamed my install, and because it is in a motorhome I didn't put on too many miles(trying to change that). After searching grounds, larger wires, direct connection to battery etc. I finally contacted Autometer and asked for suggestions. I figured I had waited too long for it to be their problem.
Their response was to immediatly send me a replacement probe. Haven't installed it yet but I have to admit they look good to me as a company at this point.
There are some good companies left out there.
I had the same thing happen with Ruger(clip not feeding) and Tasco (no power on a red-dot).
Not the same type of stuff but free replacement none-the-less.
Good to know.
KO
Ditto
Jgolden,
I'm with you on Autometer. A couple of years ago I installed Diesel Tach #2888 and for the life of me I couldn't get a reading from the probe. I tried every possible position on the alternator and couldn't get a pick up signal. I called Autometer and the technical rep sent me another probe right away.
Aloha,
Matt
