I just recently installed a aux fuel tank. The way I set it up was to come out of the draw to an electric fuel pump under the bed, from there I welded in a fitting to the steel section of the filler neck and pumped the fuel into the tank form there. It works great, the only problem is that I think the weight of the fuel is pushing it past the electric fuel pump. The fuel just dribbles out untill the level in the aux. tank gets equal to the height of the fitting in the filler neck. What are you guys using to pump your fuel?
Steve
Steve
