bcbender
Hello all. I was going back and forth on aux tank vs. Titan 55gal . Mopar 50gal but since I assume the Mopar 50 gal would be cost prohibitive, but then I landed on a great deal on this RDS 60gal tank.
I have decided I am going to make it so I can take in/out so when I want my 8' bed I can which will not coincide with me needing 90 gal of fuel. That being said I see no kits to install on the 19'+ MY models. I was thinking to remove the filler tube and weld a bung in it to connect the 3/8 line from the tank but cannot get the FSM to know how to properly remove it, I don't want to damage the filler tube, or anything since the truck is NEW and not ready to break things in the process. Do I need to also connect the vent line to the tank vent? I was thinking about mounting a small pump, Normally closed check valve, and really good! water separating filter down under the bed so that I can pump it though a filter into the tank when I hit 1/4 empty on main tank. I think I saw some 100% water absorbing filters somewhere here on the TDR, not sure how big a pump (GPH) I need to push fuel through them. Thought was topside I could simply use some turnbuckles to tie it down and a hydraulic quick connect for the fuel line.... Thoughts ? Ideas? Tech Authority is "out of stock" on FSMs so I may have to wait to pull the filler neck.
