Wiredawg
So I read the tread on Cummins forum, and I think I am going to give Ltngdrvr's install a go. I have everything from the previous owner's install except the pipe with the check valve in it. Does anyone know if /where you could purchase just the brass valve? I would prefer to pull the filler tube and simply weld a bung in it, then re-install with out the extra pipes, etc.. and since I already have the shutoff valve on the tank and the vent / fuel lines, the only thing I need from the kit is the check valve. I am having a hard time with spending almost a $100 on the RDS kit for that valve. Is it just a simple differential pressure valve?
If you want to try my useless setup, bought all the hardware at Northern Tool and bought the fuel line at Advance. I just happened to go with the size that the factory TDS fitting supported.
EDIT: I dont keep RDS valve open, but when primary tank gets down to 1/4 tank, I open it and forget it. Never leaked a drop.
BTW, my application is for a Cab and Chassis. but the RDS tank doesn't care.
Cheers, Ron
