Topzide
My 2014 has the factory AUX switches along with what's refereed to as aux wiring that runs to back of truck. Question is, when installing the jumper harness into plug under the dash would provide both a hot and ignition switched power wire running to the rear of the truck, has anyone discovered these and where shall I start looking? The reason I'm looking for them is that I'd like to add some extra reverse lighting. If I can find the ignition feed, I'd be able to add relay from tail lights to "new" led reverse lights. Way to cold to be out poking around under the truck in the driveway! Also, what chance of success would I have trying to use a toner to track down these wires? Thanks from any and all help provided.
