I swapped Axels from 3.55 to a 4.10 recently.I have read everything on the web on ABS lights.But my situation is different,it does not come on until I get up to 55 or 60 miles an hour.i changed the sensor on top of the Axel,problem still exist.I did a complete brake job on the new axel before I installed it.Bleed the brakes and adjusted them.The brakes work great with the Chevy cylinders that I also installed.The master cylinder is full.The ABS and red brake light come on at the same time.The ABS wiring is in good shape.Truck is a 1998 3500- nv 4500 -4x4,pretty much stock with a Gear Vendors.....Thanks for any suggestions...Robert
