Details here: TDR Privileges
the vent shold be on the axle tube where the brake line drops to the axle and Tee's off the vent tube is the bolt holding the Tee down
as far as the leak just change the seal if its a dana 70 or 80 they use shims for bearing preload and you just pull the yoke change the seal then put the yoke back on and torque to like 400 ft-lb on the 70 i thnk and on the 80 ist 440-500 ft lb i know that one cause i just did mine
