Engine/Transmission (1998.5 - 2002) B1 - Twins ???Questions???
Engine/Transmission (1998.5 - 2002) Repair of a lift pump
2nd Gen Non-Engine/Transmission Headlights act up some times?
Yes. the increased volume of the turbos will need more exhaust flow than a 12cm housing will handle. the WG will shunt it around the little turbo into the inlet of the primary.
Thanks,
Mark
Kurt said: "If someone would just custom build heads for us then we are ready to go!!!"
:rolleyes: Someone is building billet heads, but they ain't talkin'.
Matt
MY TURBO IS DEAD!
Guy's
My turbo just died on the way back to college. I was woundering if i could run a B1 on a stock truck? If not what should i put back on because i like to bark my turbo and i want to throw some power at it. Let me know guy's.
Thanks Andy
TurboTweeked! ;)
You could install a KSB-1B. This is the fastest spooling Version for your truck. Then as Mark K replied a PE EZ, PE Comp or Equal would be a nice addition.
And as DHayden replied - the B-1 Bomber Turbos are the only Turbos that I would intentionally "Bark" without worry.
I have a few customers with the Standard size B-1 on 1st Gen Trucks with only mild fueling mods and they are Very happy. Their HP range as low as 250 and UP. The KSB-1B is two levels "Kwiker" spooling.
Call me if you have any questions. Thanks Kurt Yardley
505-534-0434
i noticed a few of you guys have the camshafts, how was the improvement after doing the upgrade?? i am thinking about doing that, or possibly going to a B1
