engine knock was the last straw I called a freind to get me with his duramax but thats not the point its deeper than what you drive. in two days he was there 991mi with his trailer so when some one said the duramax had to rescue the cummins I said "he did 2000mi in 48hrs because I needed help who can you call to do that for you?" that shuts them up. I would do the same fore him no questions period.
the short block from cummins would have been $4150.
the local WV shop quoted a good used short block 110Kmi for $1000
so the call was made.
not only did we arive on sunday and wanted to drop the trailer and not bother brian (owner, lives next to his shop) but he came out and wanted to diagnose the knock before we could leave and get some rest. we worked on the truck until midnight. wile cheaking comp ect. we were moving to reposition it on the lift at 1100rpm #6 rod came thru the starter side. problem found!
short block $800
the trans has needed rebult since I first met brian 3 years ago sooo... ...
tunrite triple disc converter $1100 w/core
tonys reinforced flywheel $150 excange
ats billet input shaft $700
seals clutches ect $150
trans mount $20
set tolerances tight (race only)
converters= you get what you pay for wow I like the triple.
brian let me use his shop on nightshift and tools and all no charge. the whole thing took all week 40+ hrs and $3000 so there really is not much question why we brought the truck that far what would you do?
I am happy with it over all. the dv's are wow! pinched off the waste gate and the truck puts out 50lbs boost! my goal is close (500hp) smoke is heavy and a lot freight train like.
I wleded the rear and took it to the drag strip 3rd run launced @ 10lbs (no spin) and did a 9. 53 in the 1/8 mile (no 1/4mil in WV)
brian run a 7. 96 in a 24v ex longbd 4x4 water cooled single charger edge ect.
this world needs more men like this he is a true freind.
thanks to Vannest Performance I am up and better than ever!!!!!!
short block $800
trans mount $20
