Ball joints
Brake Flushing
dr. performance
Has anybody had any trouble with there ball joints or any front end problems,got a clunking noise up front but can't seem to pin point it,I have heard of some 2000 3500s having some ball joint problems. Thanks
David Foster
On my 99, I have replaced 3 trackbars (2 were somehow bent and 3rd worn out. The fourth one I paid for and got a moog). I have also replaced the ball joints on the drivers side, as well as steering stablizer. I am getting ready to purchase an agr steering box in the next week or so to take care of the play in my stock box.
99 2500 4x4 QC Std transmission, Purple, 10 Disc Sony Changer, 285x75Rx16 BFG Mudders, Gooseneck hitch, 275lb King Klaw front bumper, Towing/Camper setup.
DDIII's, Exhaust, TTPM, Clutch, Guages are now installed an it rocks (fastest farm truck around).
1965 Chevy 1/2 ton Pickup, 350-350hp/2spd powerglide, PS, PB, Disc Brakes on the front, Tilt, Fuel Cell, 3. 73 posi.
26ft Gooseneck Flatbed Trailer.
1960 Farmal 340 Diesel Tractor
I had all four ball joints replaced on my '01 @ 3K, yes, 3,000 miles.
Apparently, they weren't greased!
Shane Oler
'01 2500 4X4, ETH/6 speed, Pyro (pre-turbo)and Boost Pillar mount, Dark Garnet/Camel, 4" exhaust (still in the box... It's freaking COLD in Oklahoma!:(), Kenwood stereo w/10 disc changer, NON-OEM Infiniti speakers x 4, 10 inch sub, two 150 watt amps, lots of country and classic rock!20K Reese 5er hitch
Other: '70 Olds Vista Cruiser 455 (future resto project)
30' Sandpiper 5er Super Slide bunkhouse(about 10k lbs. )
I have had ALL of the ball joints, the steering gear box, the track bar, the steering stabilizer, and the torsion bar replaced on my 99 before 33K, and now at 55K it is in the shop as we speak for the same symptoms as the last time. The new ball joints put on it last time all had grease fittings and I have greased them every 5K, so maybe they are OK this time.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S SPA Boost/EGT Everything but leather NRA Member Great Lakes TDR Member
Look for my post "Ball Joint is Junk" Dave!
My left lower ball joint was so loud and stiff it felt like it was frozen. When I went to my 5Star #ad
Dealer the Tech had me stand on the rocker panel and rock the truck for about 10 min. After he isolated the noise he took a propane torch to the ball joint and got it to quiet down. I will be bringing the Ram to have the ball joint change this Wed. Get this, the Service writer said they would take it off, inspect it and SEE if it NEEDS to be replaced. I am ready for one h_ _ _ of a fight! What ever form of lubrication it had is now melted and pooled somplace inside it!
My truck has 3080 miles on it. This is a common problem... and the replacement is the same kind... sans grease zerk! #ad
White 2001, 3500, Auto,3:54 (soon to be 4:10),QC,2WD,LB,34' DBL slide Cardinal 5er
I just replaced uppers and lowers on both sides. Driver's side lower was extremely loose, tire moved . 5-1. 0" while truck was on the lift. Replaced with Spicer ball joints with grease fittings on all four.
98. 5 24 valve clubcab custom dual exhaust w/5" tips, Autometer pyro & boost gauges, K&N filter, 4. 5" Skyjacker lift kit, 36"x14. 50. 50"x16. 5" Mickey Thompson baja belteds, PE-EZ, 275 injectors, no turbo silencer ring.
What brand are the ball joints you guy's are finding for the 98. 5 and 99 truck? What store are you buying them from?
I called Moog and they said they didn't have them. Could not find them in the TRW catalogue either.
243
99 QC 2500 ST 4X4 SB 24V/5speed 3. 54/LSD Driftwood/Agate
Walker 21468, VDO, Bridgestone 285/75/16 MT's, RS9000's, Hella 500's
http://www.0hassleisp.com/dwilk/243'sRamPage.html
-- email address removed --
