Engine/Transmission (1998.5 - 2002) banjos
Engine/Transmission (1998.5 - 2002) Pre - Post turbo / forward or back
Reply back to tell us how well, or if you feel a difference when you have installed these. AS for the question, I dont really know for shure. I would say no, because when I have changed injectors I havnt noticed alot of pressure when removing the fuel lines. Sorry I couldnt be of much help.
Banjos?
20,000psi???? No. The banjos are in the low-pressure supply to the injection pump; 10psi if you're running and the lift pump hasn't completely calved... Pressure in the lines with the banjos goes to 0psi when the key is turned off. All you will be dealing with is a bit of dribble.
