Banks gauge lights
Isspro's new line of gauges
Jordan 2020Brake Controller Install
Called Banks this week and they could not help with info on getting there gauge lights to match closer to the stock bluish color. Isspro and autometer have colored bulb covers and so far seem to be a different size bulb. The banks I have uses a GE 53
bulb . Has someone solved this problem? In the past I know the senders usually have to be matched up with the gauges and did not want to replace the works. Can't imagine why banks hasn't taken this in consideration. Thanks RJ
I just bought the wife a 98 12V with the Banks kit on it. The gauges are mounted low below the ars tray. The thing I don't understand in 2 gauges and 2 different lights. One is the slide in type and the other is a GE insert and turn. The slide on one I have a color bulb, the other I can't find one.
Any ideas?
Preston
Turbo tom ,I have the ge ones. If the holes are the same maybe we can switch holders . On the transmission temp it looks pretty shallow for the bayonnet bulbs havent checked the other gauges. Mine are in the drink holder spot. Thanks RJ.
