rbattelle
DBond said:I guess I have to explain every statement I make here to steve.
:-laf :-laf [insert sounds of sinckering]
jelag said:I' you should see close to 15 + volts at the plug... Now plug in your trailer and let it charge for a bit and measure the voltage at the trailer batteries... if its under 14. 7 volts the batteries will never come up to charge... .
I hope you have some really good batteries 14. 4 volts is the industry standard for battery charging and 13. 7 - 14 is the normal float voltage 14. 7 - 15 would be considered an equalizing charge which if you are doing on a regular basis will boil the battery. Just curious how you find that under 14. 7 volts you will not charge the batteries?
WMcGuire said:... . I'm curious as to if there is anything to prevent the truck's electrical load from pulling power from the trailer batteries??
klenger said:See my webpage at http://www.klenger.net/dodge/7-pin-connector-installation/index.html for a correct interpertation of the drawing. The drawing is NOT for a factory cable. It is for an aftermarket Reese cable.
fkovalski said:I would like to be able to have a similar setup, but tap all 7 wires rathewr than just 4 to route what ever I need without cutting into the fatory wiring harness... does such an animal exist?
fkovalski said:I too am concerned about this happening. I would like to install an isolator without cutting into the truck's harness. Is there an isolator that can be connected (in series) and mounted in the RV.
cosborne said:Dodge is the only one to not use a disconnect in their trailer plug for the charge wire. Ford and GMC have this built in. The simplest solution is a $12 continuous duty solenoid at the battery for the charge line. Most camper install shops have these. If you don't use one (or something) and keep your plug plugged in you WILL drain your starting batteries... .
