BD 4" exhaust installed - some notes
A 3 piece tonneau cover?(gull wing)
1st post, happy with products
I installed the BD 4 inch exhaust system tonight, purchased from DIS. Took about 4 hours and as normally happens, I can look back and say it shouldn't have taken that long.
Had fun breaking loose the two bolts between the turbo and the downpipe. Breakfree helped, but I still barked up my knuckles.
After tediously attempting to unbolt all the other clamps and hangers for awhile, I finally realized I wasn't going to be putting this old junk up for sale on Ebay, so out came the sawz-all! Now we're getting somewhere!
I hung the new system in from front to back, leaving bolts and clamps loose until it was all in place. Then I made final adjustments and tightened it all down.
In general the fit of the parts were good, but I have a concern about the clearance over the rear axle. It looks to me like the straight section in front of the muffler should have been a couple of inches longer. The section that goes over the axle seems to be a skosh too far toward the front of the truck. I expected the "peak" of the bend in this piece should have centered right over the axle for maximum clearance, but it doesn't. I'll be watching this the next time I load it up heavy to see if clearance is a problem.
Went for the long awaited test drive. At an idle it is scarcely louder than the stock system, but it sounds different, almost as if you can hear the air flow better.
At first signs of boost, things get better. Has a nice throaty tone to it and, coupled with the Moparguy airfilter, the silencer ring absence is beautiful! Some have posted that it gets to be too much, but I like it so far.
I'm also happy to report that I don't have the "drone" that some have posted about. I did not tack weld any of the joints either, but cruising at different speeds I was not able to produce any undesirable drones or resonances. I was initially skeptical when I saw the hangar system and wondered if it would slop around under there, but it is rock solid.
My truck is due for the 30,000 mile transmission fluid change. Can't wait to see the reaction at the dealership when Blackie rolls in with gauges, exhaust, and the big old bumper in place. Bet they go looking for the chip I haven't bought yet... ;)
JimD
Congrats on your install. Its pretty darn satisfying to do these things yourself... seems like everything on the truck works better afterwards!
The Moparguy filter system is sounding better and better each day. All of that for under 40 bones. Think I'll go get one tomorrow.
2000 qc, sport,v dually, 4x4, auto, every bell and whistle except tow mirrors and snow plow, autometer egt and boost on the pillar, billlet grille, ss nerfs and bed caps, tonneau, tinted windows, performance bombs in the near future.
Kurt,
The muffler I used came with the BD kit. It is just a big can, about half again as long as the Moparguy airfilter. From what I can see, it would provide very little restriction. You can see straight through it but they crimped the pipe on 3 sides. You could probably still drop a 2 or 2. 5 inch ball down through it. (maybe even the shift knob off a dead Phord) Just ahead of the crimps there are holes drilled in the pipe walls, and then more openings past the crimp. I don't understand muffler theory but it looks to me as if the crimps are only meant as a slight baffle, and then the holes provide an alternate path around the restriction, minimal as it is. I bet this results in some scientifically researched turbulence that was meant to make my truck run a 13 second quarter mile someday...
Around the rural area I live in, folks are real accustomed to diesels now and it's no big deal. But this sounds different enough to turn heads - it's really funny!
JimD
