I installed mine last night and will post pictures. Pressing in the rubber bushings can be done with a vise; however, using my press was a lot easier. Installing the rubber bushing into the U shaped bracket does take some patience, lube and a should be done before installing on the vehicle. Attaching the top part of links to the sway bar on both sides and then attaching both bottoms will give you best results. Tighten upper rubber bushings so that they squeeze to just the outer edge of the washers. The bolts that go through the lower two bushings say to torque to 110 lbs and this takes it down to the inner steel bushings. After torquing to the 110 lbs make sure the link is still somewhat straight or correct angle. The joints do seem quite tight and it will be a while before I use it to tow and then I will see if it helps the suspension sway or ride. Time will tell if BD did their homework on the BUSHINGS FITTING TIGHT, if not maybe we can get the upgrade when it comes out. :-laf
