BD Torque Lock
Fuel Pressure gauge
HY35 to HX35
I want to add an Exhaust brake to my 01 4x4 auto. Aside from the better TQ and valve body i need to get, do i need the Torque lock too?, or is that something that is a luxury so to speak?
TORQ-LOK IN THE WORST PRODUCT THAT YOU CAN BUY.
DO A SEARCH IN THE ARCHIVES
YES I DO KNOW THAT I AM YELLING BECAUSE THE PRODUCT SUCKS
I second Bob's opinion as many other owners of the product that have had failed TC's because of it.
TAZ... 2001 2500 SLT+ 4X4 Auto ETC Cummins, LSD 3. 54,Quad Cab, Long Bed, Agate Leather, White/Driftwood Exterior, Sliding rear window, Camper Special Group, Towing Group, Cab clearance lights,SPA-Technique Digital Dual Gauges (Pyro/Boost, Trans pressure/temp) Aux. Backup lamps. BNM 5th Wheel Hitch, Additional Body Molding on Bed. Line-X bed-liner. DTT's TC & VB, Pac Brake, Power Edge, Edge EZ, Grover Air Horns
2000 32' Aljo Triple Slide 5th Wheel.
http://www.ramtaz.com
Add on's to come: any other Ram Runner required modifications...
Ditto the last two posts above this one! In fact, if you really want a TorqLoc, I will sell you mine... just look for the ad in the Classified section. I can't even seem to "give" it away for $75. !!!! They list for $225. !
If you ONLY use the TorqLoc in the green (or AutoLoc) mode, you will be ok... but what if someone else is driving your Ram?
EMD , which e brake do you plan to get ? DTT has a smart controler that will NOT allow you to DESTROY your NEW TC if you so desire ? DON'T get a Torque Lock unless you enjoy removing your transmission and dropping $1000 a pop for a TC everytime you smoke the lock up clutch .
Ok, thanks, that answers that question. I was going to go with a Jacobs or BD brake. I would rather not do anything to my transmission and leave it stock, but i am guessing it would fry it
emd , confusion here , did you say you have a stock transmission ? also you need some type of controller that will hold the TC locked while the ebrake is on , BD has an auto lock for this function . the reason for the bad mouthing of the torque lock is its feature that allows a person to manually lock the TC whenever you want , that is what will kill your TC .
bd could save alot of face if they just discontinue that product , but money seems to be the motivating factor behind its still being available ... #ad
For what its worth, I have one of the DTT Smart Controllers in my truck along with a PacBrake and I love it. Bill's controller (along with his TC and VB) is the only way to go when putting an E-brake on an Auto.
STAY AWAY FROM LOCKUP SWITCHES!!! ESPECIALLY THE TORQUE LOK!!
Kev
