you forgot to say if you truck is intercooled or not, The early 91's where not, With that said if you get the PW's and your truck is non intercooled you will have less fuel flow ie less power than the stock injectors. On the other hand if you have a later 91 the PW's should show a gain in power. But in my opioion i say go with the bigger injectors, too many people on here make the mistake of buying lower powered stuff only to replace it down the road with more powerful equipment. if the lucas injectors where too much power for your auto you could always adjust the pump down or change the fuel to come in later. anyways i say go with the lucas injectors either way
