Best Mud flaps
2018 Laramie Bed Trailer Plug?
how long will a 68RFE last
I removed 2" off the top of my DuraFlap rears and raised them 2". They were too low to the ground since I run my rear air ride in the lower ride mode.
on my 2017 3500 srw the bottoms of them are 9.5 inches off the ground and are 12 wide (they are the standard length and width but they make a long version and a wide version Mine stick out the side at least an inch if not more as the truck body rounds upward.
duraflap.com
Just installed the OEM flaps. They are 21.25 Wide (Dually) and 5.5 " off the ground (4x4) using the lowest option placement hole. They cover just fine.
Duraflap again!!
If your really worried about snow and ice build up, spray a little WD-40 on them. I know, it's a silly step but it helps..... with mud to
I installed Duraflaps. The are nice, however, the hardware for rears is a joke. I used panhead phillips stainless steel screws and washers with nyloc nuts to hold them down. The flaps come with a crappy little set of clip nuts for sheet metal screws when installing on the rear. I highly recommend dumping those in the trash. Good product otherwise. They look great.
Ditto on the Duraflaps. Great customer service as well. Needed mine quickly for a trip I was taking and they expressed them at no cost.
Duraflap! This was 13 years ago and these same flaps look just as good, had them cut my company logo in the SS weight, just a fine product!
When I purchased my truck the Mopar flaps were out of stock . Heard about duraflaps from this forum . Asked that they be installed . Much better coverage than the stock Mopar flaps . Thanks for the recommendation guys . Best flaps on the market .
