Before ANY mods are done to your truck, establish a baseline set of readings/figures/results.
You do this with gauges.
Do some runs under different conditions, such as humidity, outside temps, RPM's, throttle positions, loads, EGT's, even stopwatch runs 0-60 ( 3-4 times and do an average), dyno run if you can get to one or afford it too, etc.
Do this with consistent tire pressures, on the same sections of road, hills etc. Keep track of smoke by assigning a numerical value such as 1= little or no smoke, 10=destroyer on full smoke turn...
Record them ALL !!
That will give you a great basis on which to compare any and all mods you make to show what you have gained or lost and where.
This is the only real way to know for sure if you have made progress or not.
Bob
