Better winter performance though REDUCED air intake flow??
Yes, that's correct-- better performance for winter operation by REDUCING air intake flow! Note, this only applies to running around empty and at light loads, not towing heavy.
I've tested this the last two winters, one with my BHAF, and now with my PowerCore prototype filter.
I've concluded that to a point, less is more.
Now, I'm not talking about a restrictive air filter. Rather, I'm talking about blocking off part of a higher-flow air unit using duct tape.
There are a number of reasons to duct tape off your intake:
1) The reduced airflow to the turbo will raise temps, and help your engine get up to temp faster, which reduces wear and helps with combustion efficiency
2) Blocking off the intake reduces the hp is takes to drive the turbo, because the the compressor is compressing air that's less dense, and it takes less work to spin through thinner air.
3) Engine is MUCH quieter-- not just turbine whine. Turbo whine is GONE completely (even w/o silencer ring), but overall engine noise is just much less.
4) For winter operation, average EGT goes up-- and this is a GOOD thing if you aren't working the engine.
5) Reducing the surface area the filter can breathe through increases air intake velocity.
With my BHAF, I duct taped off the entire thing except for a "window" about 3 sq inches (on the engine side of the bhaf to help pick up exhaust heat). It worked great-- killed turbo noise, improved winter MPG and helped the engine warm up a lot faster.
Now, with my PowerCore filter, I've taped off almost the entire 10. 5" inlet, sealed with duct tape, less a sliver of exposed filter at either side. For normal driving and hwy cruising, EGTs are well in hand, only slightly higher. I DO NOT use WOT with the setp, as the engine just can't breathe. But 15psi of boost is useable imo.
Repeat, this is NOT a setup for WOT use. It's for daily commuter usage and perhaps very light towing when the temperature start to get down around freezing.
So if you live in a Northern climate like me, and have a BHAF or AFE setup, and don't tow over 4K pounds or so, THIS IS SOMETHING YOU SHOULD TRY.
It's not for everyone, but if you find yourself in similar circumstances, there are MPG and other benefits to be had.
Justin
<!-- / message --><!-- sig -->
Justin
