THe powerpuck won't kill your injection pump.
It does not exceed the limitations set by BOSCH. The VP44 can pump out 330HP in "Emergency" services (e. g. Ambulance)
If there is a place you don't want stuff failing, it would be an ambulance.
A Power Edge COMP, TST COMP box, Blue Chip Box (redline and FMS), and any other box that pierces the injection pump wire overides any computer control that is programmed inside the VP44.
At that point, Injection pump failure could be because of overheating of the solenoid, or just from a bad pump.
If your pump doesn't fail within ~30 minutes of putting on a Wire Piercing box, then it most likely will not fail from a direct result of the fueling box.
TST has tested the Solenoid inside the VP44, and found no more power after ~69% Duty Cycle (That is not an exact number, but close).
If I can hijack this thread,,
Buyer Beware of the new FMS Redline box from Blue Chip. You can control duty cycle of the solenoid to 100%. This will lead to failure of the VP44. Many people will take this risk while in competition, and many wil pay the price to win...
(The Redline box does have an adjustment for the Duty cycle of the solenoid, so it does not have to operate at 100%)
Merrick
