BHAF and MHAF Prefilter
30psi Westach fuel press
Tie Rods
Check out http://www.outerwearsracing.com/
These guys will make you a custom prefilter for the BHAF. They have "regular" and "water resistant" versions. The water resistant version helps address the concern that some have expressed about "what if" this filter gets wet, and either version can be expected to extend the life of the BHAF or MHAF by keeping bugs and other stuff out of the pleats. The prefilter can also be washed at least a few times and used again. I was told the prefilter would filter to about 5 microns, but don't know if this was a true "nominal" rating or just a salesman giving me a number because I wanted a number.
If you call to place an order, have the filter diameter and length handy.
The MHAF is what some are calling the Fleetguard AH-1141. It looks almost exactly like the BHAF, but is 8. 5" diameter vs. 10. 5" diameter, and like the BHAF fits the existing air box hose without any special adapters. Like BHAF, there is a "marine" version that adds an internal cage, but at a price, if you want greater assurance that a wet filter element can't collapse. The MHAF gives you quite a bit more more room around the filter for clearance between the filter and other stuff, thus leaving more room for fabricating shields, etc. It has quite a bit more area than the stock filter, but less than BHAF. It's also a bit cheaper than the BHAF.
I have no affiliation with Outwears; just sharing info about a product I'm happy with.
After adding the Outerwears cover to my brand new MHAF, I realized I've reached a new level: I'm accessorizing my accessories. :eek: :D
I am still waithing :rolleyes: on my BHAF from the Cummins dealer. Should be here this Friday!!! I would like ot order one of these prefilters... . Do you mind me asking what yours cost? How long did you have to wait? One more question. What size do I need to ask them to make me for the BHAF? 10. 5" diameter by what????
Thanks,
I just contacted the company and gave them dimensions and a part number. I will let you know what they say about making us one. brian
Fleetguard lists the BHAF as 10. 5" diameter X 11. 88" long.
I'd keep it simple and tell Outerwears 10. 5 X 12", or by 13" if you want a little extra to get more "wrap" at each end. They had it to me in 10 days or less, not bad for a custom order.
I think for the MHAF size I paid ~$25, +/-
True, it approaches the cost of one filter, but I'm hoping to get some improvement in filtration and at least double the life on the main filter element, so I think it will be economical in the long run.
Hey guys the NAPA that i used to work at has a filter cleaning service that comes every week. they charge about 1/3 the cost of a new filter and can clean a good filter @ 3 times before its junk. any good truck shop should have a filter cleaning service. give it a try , maybe even get a spare. later! keep on RAMMIN'.
I thought the Fleetguard marine version some people were using was the AH-19002. Anyone know the difference in this one and the AH-1141?
the BHAF is AH19037(<> 900+cfm)
the MHAF is AH19004
the AH19002/AH1141 (<>470cfm)are just smaller in diameter and have about half the flow but still beat a stock filer by 180 cfm (stock,=<> 290 cfm)
Part: AH19037
Manufacturer: FLEETGUARD
Part Type: Air Housing, Disposable
End Connection ID: 101. 6 mm (4 in)
End Connection Height: 35. 052 mm (1. 38 in)
Largest Housing OD: 266. 7 mm (10. 5 in)
Overall Height: 301. 752 mm (11. 88 in)
Additional Information:
DONALDSON ECB105006
For Marine applications, use
AH19004 For Marine Applications, use AH19004
Product Comment
Disposable Housing Unit
Part: AH19004
CUMMINS 3924541 DONALDSON ECB105013
For Non-Marine applications, use
AH19037 For Marine Applications, use AH19004
Product Comment
Marine applied Cummins B & C engines
Part: AH19002
Largest Housing OD: 215. 9 mm (8. 5 in)
Overall Height: 314. 452 mm (12. 38 in)
CUMMINS 3924540 DONALDSON ECB085024
AH1141 For Marine Applications, Use AH19002
Product Comment
Marine applied Cummins B & C engines.
Part: AH1141
CUMMINS 3912020 DONALDSON ECB085011
AH19002 For Marine Applications, Use AH19002
Product Comment
Disposable Housing Unit For Marine Applications, use AH19002
Hope this helps... .
PN wr3325-105 price is 22. 10 1-800-967-3450 ask for scot, this is for the large napa2790 and the prefilter is water proof. size is 10. 5 dia. 10. 5 long brian
