Billet 46RH/47RH output shafts?
Need Help With-Carfax Check!
Are there billet output shafts available for the 46RH/47RH? Heard awhile back that DTT was getting some made, but never heard anything more...
Chris
There are billet input, intermediate, output shafts and drums available for the 47/RH/RE and I believe they will fit the 47/46RH will interchange. There a couple of flavors of billet material available also.
All the major builders offer the billet option and they can be bought at different HiPo places also.
Watchya buildin'? :)
Output shafts are interchangeable on the 46RH and 47RH, but not with the 47RE, right? I think the RH's have the longer shaft. I've found a few places that have the 47RE output shafts, but none for the RH trannies.
This is for the trans in my p-pump'd '93 - a 46RH. And yes, it will need billet shafts ;).
Chris
Yes the RE shafts are shorter, no governor as it is electronically controlled. The others are the same I believe. I would just call one of the big 4 and see what they have.
I am saving my nickels and dimes for the trans rebuild with billets. I need to quit doing 10 psi launches or I will be getting them sooner than I want. :p
