Blue Chip FMS-More questions!
Hi guys, more questions for you. Thanks in advance.
Ok, I know the basics of power for the diesel engine but I am new to the BOMBing aspects. Fuel plus air equals power, but I am confused on some other things, especially the Blue Chip FMS Premium, plus injectors.
1) Can someone explain how fueling boxes work with a stock engine and also in conjunction with a timing box? Will the timing box clean up the smoke from the fueling box?
2) If the Blue Chip can give the engine 63% more fuel, how much fuel will the engine actually burn both with stock and stage 2 or 3 injectors? Obviously more with the bigger injectors, but how much precentage wise? How much is being burned and how much is going toward the "black cloud"?
3) How much power could I expect with the Blue Chip, 4" exhaust, open element filter, and stock injectors, opposed to the same setup but with stage 2s or 3s?
4) If Injector ABC adds XYZ power to a stock engine to get XYZ+stock power, would adding a box add box power, injector power, plus stock power? Or would the combo cause the injectors to be less?
Let me give an example. If ABC injector adds 120 HP to 235 HP engine, the combo would be around 350 HP. Would adding a fueling box with 150 HP put the engine at about 500 HP or less?
5) Would a fueling box such as the Blue Chip plus a timing box be ideal? Or is injectors and a fueling box better, if I don't mind the smoke?
Thanks very much!!!!!
Nick
Nick
