Blue Chip vs. TST
My Dyno numbers with Edge EZ Box!
oil leak
I am intrested in the new Blue chip wizard system that has a digital EGT and boost Gauge . Sounds as if the unit also can be used for knowing when fuil preshure is low also.
I am wondering if some of you guys that are using the blue box and Powermax can post some insight??? I have beem trying to get ahold of blue chip, but their web site has never worked also the phone # in the last TDR issue does not work either. The New blue chip just look like it has more to offer than the Powermax in the engine management area also the fuiling can be increased in 1% steps.
The Phone # for Blue Chip is 888-4720-7373
. I have had no problem talking to him with this #. The e-mail is chip@bluechipdiesel.com
Hope this helps
Kent
That recent post of theirs caught my eye as well. I just tried their website and it worked OK - the URL is http://www.bluechipdiesel.com. I've sent email inquiring about this new product as it is not yet liisted on their website. No reply since sent 3 days ago. I'll probably have to call...
Kurt Voss
+++++++++++++++++++++++++1999 2500 24VCTD AUTO 4x4 QC LB Laramie SLT, Luverne stainless steel nerf bars, 3 piece bug deflector, mopar mud flaps, Line-X bedliner, unBOMBed... . yet
You will like the TST powermax.
Their powermax (adjustable version) with the integral gauges will be available in a week or so according to Mark at TST.
They have top quality stuff! You might surf their site at www.tstproducts.com for a picture of it.
I think it retails for 1099, a bargain if you add the price of the adjustable powermax, plus seperate gauges.
Call and get your name on their wait list, they will go fast!
Andy
Thanks guys the site for Blue Chip for some reason now is working, I have no idea why it wouldn't upload before. It looks like I am a little premature on this box disition since neither one has really bean tested by our fellow TDR Bombers. It looks like I may go with the new Blue box, but will just hold out a few more days hoping to see what one will have the leading edge. .
2001 3500 slt+ sport HO ETH 6spd every option available Black with agate leather
3:54,Class 5 hitch,BD E-brake, BD two Low Kit, K&N filter
I talked to the folks at Blue Chip today. The beta units are fully functional with the exception of the low fuel pressure warning. It comes with the pyrometer thermocouple. Also the electronics and display are in a "plain aluminum box" with the final product to be anodized and etched. They also plan on offering a housing to mount it on the dash. Hope this helps.
Kurt Voss
I like TST!
And the adjustable PM is out 'cause I talked a friend of mine into buying one... came in early this week and I'm installing it for him Sat.
My PM2 is upgradeble (has jack on back) to the remote adjustable for $150. Mark Chapple also provides great technical advice and customer support.
Wiredawg
2000 4X4 SLT QC 8' bed; 6 spd, 3. 54 ; BD exhaust brake and 4" exhaust syst; TST PM2; Airlift Super Duty rear air bags; RS 9000 shocks; pyro/boost gauges in 2 gauge a-pillar mount; back preasure gauge mounted under dash; KN air filter; Brown's Welding brush/grill guard, rear bumper & headache rack; nerf bars and aluminum roll top rear cover, Warn front receiver and Hadley air horns, 20K Reese hitch,Mag-Hytec dif cover.
I still love my Blue Box... wouldn't trade it for anything out there. Its the "old" 3 wire model, and produces plenty of power! Been running it for over 20,000 miles with no problems!
Rob Hanson
1999 "Big Red", 3500 SLT QC 4X4 6 spd, 4. 10 LSD, Braided SS fuel lines, Mag-Hytec Rear Cover, Cummins E-Brake, Blue Box, DD3 Injectors, Banks High Ram and 14cm Wastegated Turbo, All-steel Cowl Induction Hood, Cummins RED Valve Cover, Rhino, Rosewood Kit, Scotty System, SportComp Gauges, TorkLift SuperHitch, Tekonsha Brake Controller, Rear Flood lights, Cobra CB, DeeZee Running Boards, BD 2WD Low kit, Air Lift bags, Hitco exhaust blanket, air horns and a Geno's "I tromped a Ford" decal. Member of BOMB! (WW NW Chapter)
MyPics.com (pics updated 02/17/01)
I'd rather be... .
Cummin than Strokin.
Just so you know the current Blue Chip and TST boxes are going to be different than the versions that will be available in the near future,because the future ones will have gauges and user settings built into them.
I have had both Blue Chip and TST boxes mounted on my truck,and I love 'em both. The TST PM3 is a little more sophisticated than the Blue Box simply because it has the adjustable remote,but in the end they both do the exact same thing... give us the overfueling we want!
-Mike
'00 2500,QC,4wd,LWB,Dark Garnet,6spd,3. 54lsd,SLT,DD stage II,Psychotty air,10-level PM3,Jacobs ebrake,Isspro pyro & boost gauges,2wd-low,Airoquip fuel lines,Smittybilt nerfs,BFG 285/75 AT's
'95 2500,Reg-cab,2wd,LWB,White/Driftwood,Automatic,3. 54open,SLT
I just upgraded my original Powermax for a Powermax3 (street version) 2 weeks ago. The box that will be out in about a week will be the one with a built in boost and EGT gauge and will have defueling based on any EGT level that you set. I tested that box when I was at TST two weeks ago but it still had some bugs they had to work out (the defueling was too aggresive). The power that this box makes is incredible. I have 275 RV injectors on top of the box (everything else motor wise stock, except the muffler removed) and on a g-tech it says I'm putting down 375 hp and doing the 1/4 in 16. 3 @ 92. 8 mph (both numbers averaged over 5 runs) - my EGT's will hit 1500 at the very end of the quarter. With my original powermax and 275's it said 305 hp (that combo dynod at 313hp at scheids) and 16. 7 @ 87 mph.
-Steve St. Laurent - President of the Great Lakes TDR
'98 QC LB (CMNSPWR), 4x4, ISB, 5sp, 4. 10 LSD, TST Powermax3, 275hp RV injectors, Joe Donnelly modifed Sachs Clutch, custom ladder bars, SW fuel pressure gauge, BD exhaust brake, Isspro turbo temp monitor, front Draw-Tite receiver, rear Draw-Tite class V receiver, BFG 285/75R16 AT KO's, (all the common stuff clipped)
I also have a PowerMax3 and the power is pretty amazing. I still say it's by far the most bombing for the buck out there (maybe I'm a little biased... lol). I've decided to enter a truck pull or two this year so I'm going to upgrade to the competition version. Whichever box you go with, be prepared to bring the rest of your truck up to a point to support your new fueling levels... clutch, turbo, exhaust, fuel delivery, etc. It's a disease... stay stock! #ad
98. 5 2500, 24v, QC, 4x4, 4. 10 LSD, short bed, Line-X liner, tow package, camper suspension, Westin nerfs, camper shell, TST PowerMax3, 275 RVs, EGT/Boost pillar gauges... Love my Cummins, no love for Dodge
Steve... nice post with the info on the box and the G Tech. Although the numbers differ slightly from one another, they are close! There is another thread on this forum that talks about the G Tech. Results with my G Tech were within 5hp of the dyno... which one is correct??? We will never know, so I will take the higher of the two!
I have the competition PM3 on my truck. On setting 5, the G-tech shows 420 hp (I've got DD Stage IIs and other stuff too). Higher settings [6 through 9] generate too much heat. I'll have to wait til I have the cash for the HX-40 to lower my temps. Heck, I've outrun everything I've tried on setting 5 anyway. Last Friday, a friend and I lined 'em up. He has a 1978 L-82 Corvette. I know, they were dogs on a good day, but he's added headers, a good lumpy cam, and heads, and bracket races the vette. He runs consistent 15. 5s @ 3500 ft altitude where we live. I had no problem pulling away from him in every gear. He had an automatic, so he would regain some of my advantage while I crashed the NV-4500, but as soon as I would pour the coal to the Cummins, he would start to fade! His normal drag car is a 70 Chevelle SS 454 [runs high 12s], and he has driven my 7800# truck. He is VERY impressed with the mighty Cummins. He said "this thing pulls as hard as my Chevelle!" Yeah, maybe pulls as hard, but not nearly as fast! 7800 pounds has a way of eating up hp.
Back on to topic, the PM3 is an awesome piece. I wouldn't pay for the "competition" version unless you're really serious about purchasing other components like big turbos, exhausts, nitro-glycerin, C4, etc. ,etc... The "regular" adjustable PM3 is awesome. The in-cab adjustability is a hoot! With the DD-IIs, I usually leave mine on setting "0" until somebody pulls up and wants to play. A few punches of the button and we're loaded for bear... or Mustangs... or Vettes.....
I suggest getting some "reasonable" injectors and the PM3. You'll love every minute of it!
98 QC 3500 4X2 ISB 5-speed; 10-level Competition PowerMax; DD Stage II's; 4" exhaust turbo to tip; Luk ProGold; K&N; Amsoiled; Pillar Mounted Boost & Pyro; etc. , etc. ,
I have the power max 3. I was impressed with the extra hp out of the box, I tow a 8500 lb trailer and I have no problems getting there with out my foot on the floor board all the time. before the pm3 my truck was taking a real beating, trying to get it up to the speed limit, now my foot is not as heavy. thank goodness my corns where hurting. #ad
Just installed an adjustable PM-3 on a friend's 2001. 5 6spd today. Really kicks. #ad
Looks like I'm gonna upgrade my PM-2 soon. Only $150 if your PM-2 has an RJ11 plug on the back.
Wiredawg
I have a PM2. How do I tell if it is upgradeable to PM3 and how much it will cost? Is it as simple as unplugging the old box and plugging in the new box?
99 3500 QC 4X4 5sp 3. 54 K&N air filter, DiPricol gauges, 275 hp injectors, Pacbrake, Westin nerfs, GN hitch, Tekonsha Brake controller, Mopar seat covers, Husky mats, silencer ring removed, Draw-tite front receiver, Rancho 9000's
Ninearrow, look at the back of your TST box. If it has a phone jack it can be reprogrammed. I believe the cost is $150. 00.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Mopar tonneau,Lund bug shield,PM tractor utility back up lights,Penda bed mat and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
