Joseph Donnelly
Would the third one be in the second place or the third place
bighammer said:I finally posted the picture that shows the raised bump that holds the switch in after the screws are removed. Took me long enough.
I think I will order the parts and do this and remove the Brite Box. One of the headlight harnesses has crack and wont hold a bulb.
I DO want to point out that there is one possible minor drawback to this mod... .
Since the "spring loaded action" of the high beam switch is incapacitated by this mod, the forward/back motion of the switch is chosen MANUALLY. Push the stalk forward, it STAYS forward, and you are in regular low beam mode... Pull the stalk back, and it STAYS back, and you are in high beam mode, with the EXTRA ability to be able to run your fog lights and low beams at the same time (just like in the "momentary" oem pulled back position. All of these positions work really well, BUT there is one caveat--
IF the switch is LEFT in the pulled back/high beam postion, the high beams WILL stay on, The blue highbeam indicator light WILL be lit and the high beams will STAY on EVEN IF THE HEADLIGHT SWITCH IS OFF, EVEN AFTER THE ENGINE IS TURNED OFF AND EVEN AFTER THE KEY IS REMOVED... until the switch is MANUALLY returned to the forward position.
Since I myself tend to go through a "shut down"/cockpit check, this has NOT been a problem for me, and the advantages of running low,high and foglights to obtain excellent forwrd lighting while driving when no one els is driving towards me, is priceless, particularly since potentially there can be zero cost to this mod, as well as NO Britebox to go out and potentially leave me without any lights at all, as has happened to others on occasion.
All that being said, on ONE occasion, I looked out from my house to check on my truck and saw that the headlights were left ON, which I never do, particularly since the oem ECM turns them off in case I forget to :-laf .
I was very surprised, and walked out to the truck and the multifunction switch was pulled BACK, thus activating the high beams, wth NO WAY for the ECM to turn them off. I realized that ealier in the day, when I had gone to my truck to get something from the cab, as I had leaned in to grab the itme from the center console, I had ACCIDENTLY moved the stalk switch to the BACK postion, where it stayed until I noticed the problem later. This in no way affects my LOVE for this mod. It has happened once, with no ill effects since I caught it well before the batteries were discharged, and now I am careful to check the switch postion before I leave my truck, even when I only lean in to get something !!
That being said, I wouldn't go back to stock for anything.![]()
