Help, my boost gauge(Westach)started reading only 10lbs Psi WOT. Previously it was 26# at WOT. (I don't know how long its been low because I rarely look at the reading, and the truck was running fine with no noticable loss of power)
I have already done the following at the suggestion of our diesel mechanic with no luck:
Checked all the turbo hoses; ran the truck briefly without the hose over the intake of the Turbo to check for clogged filter; tightened all the clamps; checked for water in fuel; checked for pinching of turbo gauge hose from the gauge to the threaded 1/8"NPT in the head behind fuel filter.
I ran out of fuel and it died last week, but it ran fine after filling up, but I haven't changed my fuel filter.
EGT's at WOT are about the same as when it showed 26#PSI.
Help
Y2K Awesome Black LB 3500 QC SLT, 24Valve ETC ISB, 4x4, 4:10 LSD, DTT Custom prepared Auto transmission VB, Power Edge 'EZ', DD2's, K&N, Polished Stull Billet Grill/Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges, Rancho 9000's, Diamond Plated Tool Box, + a bunch of other stuff. Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
Help
