boost gauge hook up
Heads, Compression and Gaskets
Burning your used motor oil with your fuel
If you have a 12v the easiest way is to replace one of the bolts in the intake manifold with a special bolt which is hollow down the center (banjo bolt?). The boost fitting then attaches to the new bolt. 24V versions are available at Piers (Piers has pictures of one in place) or Genos. I used one on my 12V that looked like the Piers bolt.
