Boost module and elbow who's better?
What is best fix for 5th gear nut problem?
sportbike injectors tested
It's for the correct years '98. 5-'00. Is there a difference between the PS and the BD's, not physically but functionality??
[This message has been edited by Justbeamn (edited 03-13-2001). ]
Does BD make a boost module?? I thought they only had the Plug n Power, which is a timing module without the boost module???
Kev
I wonder if BD module is the same as DD's?? With basically stock HP, I tried both the DD and Practical Solutions boost module/elbow. The DD gave 30psi boost with stock injectors but the engine was a dog, it was damping down the signal too much across the boost level spectrum. The PS module works MUCH better on non-BOMBed or RV-injectored trucks, since it allows the MAP to see normal boost until reaching max psi then caps it there.
Vaughn
'01 2500 QC Shortbed 2wd, 6-speed, 3. 54LSD, Cab & Fog lamps, Camper & Tow Pkg.
BOMBed: RV injectors, PS Boost module, Amsoil air filter, straightpiped exh. , Aeroquip 3/8" fuel line w/tank mounted lift pump, AutoMeter Sport Comp gauges, Line-X'd, Amber turn signal conversion.
Mildly BOMBed Performance: 0-60 @ 10. 0 sec. ,
40-60 @ 5. 5 sec. ,
0-100 @ 24 sec.
Have a chance to buy a used BD module and elbow for a good price. Just starting to "Bomb" and this is on my list. Any difference from one to another or is one better. Any thoughts?
98. 5 3500 SLT Quad Dually 4x4. 3:54 Auto, Waterfall Blk on red. Custom dually flaps, Rhino lining, All acc's w/leather, Muth signal mirrors, Catz MSC's, 55watt back up lights, Optima Red Tops,
BD exhaust brake, Banks EGT/Boost/Temp gauges, Mag-Hytec DC&TP, SS bug screen and fender trim,SS Stull diamond line running boards, SS 4" turn down.
My Dually
If it's the type the plugs into the map sensor make sure the plug matches. There was a chance on the 2001 and up models.
BTW Practical Solutions sell the module and elbow for $136. 50 delivered.
Take Care,
Bob
