Thanks for the replys guys. I guess my question then becomes, do I really need more boost pressure? This setup runs beautifully, pulling an 8500lb (empty, probably closer to 10K loaded) 5er. I have power to burn, having just returned from a trip over the Cascades to Central Oregon, I never got under 55mph in 3rd gear unless I had to slow down for a corner. I previously owned a 96 12 valve, with a banks kit, which as you know, is basically just turning up the pump 30 thousands, advancing the timing and different exhaust and K&N air filter. I have to tell you, there is a world of difference between that setup and what I now have. So... ... ..... maybe I shouldn't question my boost pressure, but was just curious because others in this forum are suggesting boost of 25psi or more.
Regards,
Roger
PS. Than ks for the tips on my signature and I will address it in my next post.
