Engine/Transmission (1998.5 - 2002) boost #'s
Engine/Transmission (1994 - 1998) Another KDP in DFW killed!
Engine/Transmission (1994 - 1998) Waste gate actuator
Tonite i got 42lbs of boost with just injectors, and 49lbs with box on kill. Does this sound right? I have bd4's, ufm, and a haisly 50/55. Is this about right or should I check for leaks? I appreciate any replies. :)
With a PDR HX-40 I get 28 injectors alone, 32 with injectors and vanaaken, and then 39 when adding in the blue box. I used to get closer to 50 with the stock HX-35. The bigger the turbo and exhaust housing, the less boost you will see for a given amount of fuel. Dlange, your numbers seem about right for the 50/55 with your level of fueling. My numbers seem a bit low to me but I belive the PDR40 is wastegated at 38 or 40psi.
Kevin
