Borgeson and Mopar linkage update ?
Colorado springs area tire shop??? 19.5
driver side electric seat adjust
I read in the last Genos Garage catalog (winter 2012 page 22),if the truck have the mopar linkage update on it,the borgeson may/may not fit on the truck.
Somebody have an idea of the problem?
Thank you !
Borgeson and Mopar Linkage update
I recently called tech support at Borgeson, tech stated that it will not work as the pitman arm will not work with the new linkage. When you buy the Borgeson box it is a different branb than original (Tech says remanufactured import) the pitman arm has to fit the box and is supplied with box when purchased from Borgeson. They make or have the arm made and only have it for the old style linkage. He stated that they will probably make one for the new style linkage at some point. No date stated.
I am considering a Redhead remanufactured box.
Good luck
M Meighen
