1999 163 k rasp and carter backup set up for fuel system.A couple years ago moved the brass pressure regulator from bottom of fuel filter to the top side of the engine for easier access. Runs 17-19 lbs normal. I carry a spare one in a small jar behind the seat so when I get a very small piece of dirt in it and my fuel pressure goes down in can do a pretty quick and simple road side change out. I change the fuel filter pretty regular and try to use the best and cleanest fuel available. At 163 k I probably should drop the tank and clean it out but what a pain. So recently I’m getting a bouncy fuel pressure gauge. Like 9 to 21 lbs. comes and goes then goes away back to normal 17-19 lbs. Sooo what do you think is the VP 44 going bad ??? It’s been on there a long time now. What do you think??
