bouncy ride with bigfoot, ranchos or airbags?
locking rears
Synthetic blend oils .... Make your own?
I've seen these options discussed in the past. I don't really want to go the airbag route due to expense and trouble of cutting the camper springs off. Anybody with a camper find the rancho's resolve the spoungy ride problem?
2500qc, no leather or abs
1500 bigfoot, no auto waterheater or microwave.
Ted, I dont have a camper on my truck but I think your best bet would be to go with Rancho 9000 shocks. They have 5 different ride quality settings that you could experiment with. From Ultra Stiff(#5) to mushy(#1). I had these shocks and should have went with them again. I loved em... ... ... ... Good Luck, Bill
1994 Dodge Ram SLT Cummins 5 speed 4x4, XLerator airfilter,Optima red top batteries,Turbo&Exhaust blanket,Magnaguard rear diff cover,Edelbrock IAS shocks,muffler removed,Borgeson steering shaft,Trailmaster steering stabilizers,Rancho upper & lower links,Polyurethane sway bar bushings,Skyjacker 2" leveling springs(front),Fabritech Stage II Traction Bars,Denman Coyote A/P LT305/85R16(36" Tall) tires on Stock Dodge Chrome 16x6. 5 wheels,Bushwacker Street Flares,Back-off saftey brake light,Bugflector II bug shield, Diamond Blue 9004 Headlight Bulbs (65 watts low 100 watts high),Royal Purple ,Amsoil& Red line lubes throughout.
1970 Plymouth Cuda (under construction)
1968 Hurst HEMI® Dart , Nah its just a screen name ;-)
Put the Rancho 9000s on and don't wait.
I waited until 19000 miles on my 97 Ram before I replace the OEM shocks with Rancho 9000s. I had 1300 miles on my 99 Ram when I put a set of 9000s on. The positive effect on the ride and control are more than noticable. BTW, I have this almost new set of OEM shocks setting in the barn if any one is interested!
Tim Edwards
time1@sssnet.com
'99 , SLT, QC, Cummins, NV4500 , 4X4, Bright White, Agate, M/T 16X8 Rims,265 X 75 R16s, Westin nurf steps, Smitty Built push bar, etc.
Ted, see the 1994-2000 Ram Second Generation. Go to page 2. See " Shocks". posted by Rotton Rob. About the 15th reply by R A Dreher has a good soruce for Rancho 9000s Bill
Hi Ted, The use of air bags do not require the removal of the camper springs. They mount on top. With a 3/4 ton / camper combo, you will most likely need them to transfer some weight forward. RonL
98 Dodge 3500 QC SLT 4x4, 12V, Auto 3. 54, LSD, Camper pkg, Running Brds, Tow hooks, Tonneau cover, Cobra / K40, Westach Boost / EGT / transmission Temp gauges, Valley class V, Hadley Dual Air Horns, Mopar Bedliner, RS 9000's, Air Lift system, yada, yada, yada.....
99 Lance 1110 Truck Camper
Thanks all for your feedback.
Ron, weight is split 50/50, or very close (5000 front, 5000 rear).
Rear goes down about 4 inches.
Front doesn't move. Does that mean I need to have rear come back up?
I ordered the rancho's. I really don't want to go for the airbags.
REAR GOES DOWN 4 INCHES, FRONT STAYS ABOUT THE SAME
REAR WEIGHT ABOUT 1K MORE THAN FRONT (5600/4600)
I ESTIMATE 10% OF CAMPER WEIGHT ON FRONT AXLE
[This message has been edited by ted kidd (edited 10-11-1999). ]
[This message has been edited by ted kidd (edited 10-12-1999). ]
[This message has been edited by ted kidd (edited 10-16-1999). ]
