I just had to change the front brake pads that only had about 20K miles on them they were the performance friction pads. Only the outer right front pad was worn badly although the outer left pad was worn about half way. Both inner pads had hardly any wear. I suspect that my calipers are hanging up. I already have it back together and this time I used some silicone spray lubricant on the two sleeves that the calipers ride on. Is there anything else that I should do to stop the calipers from hanging up? By the way, the good thing about all this is the local autozone replaced the pads no charge.
Steve
1998 2500 Quad Cab, 12V, 5spd, 4x4, HD Transfer Case, 370HP Diamond B Injectors, #4 TST, 16cm2 Housing, AFC Spring Kit, BD Governor Spring Kit and other governor modifications, Walker Muffler, 285/75-16 BFG AT's, Stainless Steel Tube Steps, Reese Fifth Wheel Hitch, Leather, CD, LSD Dana 80 Rear, 60 Front, Centerforce Dual Friction Clutch, Rancho RS9000 Shocks, Rancho Steering Stabilizer, ATS Exhaust Manifold, Psychotty Air Induction, BD Exhaust Brake, Enterprise Engine Delivery Valves
Steve
