I did not have the proper high temp grease when I changed to Performance Friction pads a week ago. I did however, lightly lube the pins with Mobile 1 synthetic grease which I had on hand. Tonight, I pulled the calipers, removed and cleaned the pins and rubber sleeves that the pins slide in. They were pretty gummed up and the pins had some wear.
My question is, why are the pins encased in a rubber sleeve? I would think that a bronze bushing would work much better and hold the caliper in alignment far better than the soft rubber.
1999 Quad Cab 2500 ST 4X4 SB 24V/5speed 3. 54/LSD Driftwood/Agate
[*] 275hp Injectors, Wastegate Elbow, Boost Module by TXRam, Straight Pipe
[*] VDO Boost and Pyrometer on Autometer Gauge Pod
[*] 285/75/16 Bridgestone MT's, RS9000's, Hella 500 Driving Lights Husky Liners
[*] Smittybilt Sure-Steps, Magellan 315 GPS mounted on shifter console
-- email address removed --
