brake controllers
Bullydog 4" Exhaust Experience
Cooper tires
What kind of brake controllers are people running and what do they recomend? I heard of a new controller being made in texas a few weeks back, but have forgotten the website. Can anyone help?
This is a frequently discussed topic. You could probably do a search and get overwhelmed with info. Bottom line: There are two favorite brake controllers, the Prodigy & the Jordan. People that use the Prodigy (myself included) will tell you they're the best. Folks who use Jordan's swear by them. I think in either case you'd be getting a great brake controller. There are differences however. Check them out and make your own decision.
Good luck!
I haul a 32/36k van to jobsites all over the continent (with F-450, not our 2500s), and spend a lot of time in the Rockies, so the trailer brake deal is a big issue with me. I have Kodiak discs on this trailer, and use the tractor to haul a wide variety of other trailers. My main trailer uses Master electric over hydraulic actuator to run the discs, and I have waited patiently for a couple of years for them to build a controller that would be able to communicate. Further, I have desparately wanted the actual brake pressure in the tow vehicle to be used for signal.
The BrakeSmart from Master (www.masterbrake.com) is finally on the market. It uses a pressure transducer in the tow vehicle brake line to do its job. It will hook up to a regular electric brake trailer and tell you how many axles it sees and set the level accordingly. It will tell you if it hooked to their elec/hyd or air/hyd actuators, and give you error messages from Master actuator's on-board diagnostics, etc. , etc.
I know many of you swear by the Jordan, and I agree, it WAS the best that you could get - but pedal position is a poor substitute for actual line pressure. The BrakeSmart is as close to driving an empty car that tow braking has ever been.
Pat
Good information, Pat! Where did you purchase it, and how much did it cost? I downloaded the manual, and it's a 'gottahavit'! Thanks
Tom
